Clutch or what??
Old 03-06-2007, 11:38 PM
Stang95GT
Stang95GT's Avatar
Default Clutch or what??
Ok...heres the deal.....I've owned my GT about a year and a half now.....it's a 5.0 of course with 225,000 miles...today coming home from work as I got on the ramp to get onto the highway I shifted into 5th and I got big revs...but no speed like i normally get......but if I slowly give it gas itstarts to pick up speed....it also is doing this in 4th gear....I push on the gas kinda hard and the revs just go WAY up but no speed.....if i ease onto the gas it starts to pickup.......is it the clutch....or something in the trans itself.....??
Stang95GT is offline
Old 03-07-2007, 12:02 AM
mcfomco
mcfomco's Avatar
Default RE: Clutch or what??
Sounds like the clutch needs some attention.
mcfomco is offline
Old 03-07-2007, 12:04 AM
FivePointOhh
in limbo
FivePointOhh's Avatar
i'm willing to bet your clutch is fried or you have alot of scoring on your flywheel. someone will chime in on this one but thats what my car did and i had zero clutch....the metal plate for the clutch was even broken my clutch was so bad
FivePointOhh is offline
Old 03-07-2007, 01:29 PM
dimebag
dimebag's Avatar
yea man its your clutch, you can adjust the pedal, which will provide a temp. solution, but either way i would start looking into buying a clutch soon.
how do i know? mine does it occasionally... shes startin to go too[:@]
dimebag is offline
Old 03-07-2007, 01:36 PM
Sick5.0LX
Sick5.0LX's Avatar
I had a 1995 300zx TT for 5 years... the 5th gear usuallly starts to go first when the clutch goes bad. I live in Fl where its obviously relatively flat, but I was drivin through ATL and my car wouldnt really accelerate in 5th or 4th over hills anymore unless I tried accelerating slowly. Got a new clutch, fixed the problem, and drove like a whole new car!
Sick5.0LX is offline
Twisted
Twisted's Avatar
It sounds like your clutch is slipping. As for the reason, either it's worn, or you don't have enough slack in your clutch cable.
Twisted is offline
Old 03-07-2007, 02:09 PM
stang2race
stang2race's Avatar
Cashed in clutch, and probably a glazed flywheel.
stang2race is offline
Old 03-07-2007, 03:26 PM
Twisted
Twisted's Avatar
Also, I believe if your rear main seal is leaking, it can foul your clutch and cause it to slip.
Twisted is offline
Old 03-07-2007, 08:29 PM
Stang95GT
Stang95GT's Avatar
Thanks for all the info guys.....well...guess i'll be installing a new clutch this weekend.....Thanks again......
Old 03-07-2007, 09:29 PM
gspfunk
gspfunk's Avatar
W/ miles like that, replace these as well:
Ram HD clutch disc (possibly pressure plate) - $160 for clutch/PP/alignment tool/Throw out bearing
Rear main seal - under $10, IIRC
Pilot bearing - $12
HD clutch fork/bolt - $40
Clutch cable - $25
(Quadrant/Firewall adjuster) - $60
gspfunk is offline
Thunderball
15
11-22-2015 11:49 PM
junior04
09-28-2015 10:53 AM
MacSerio
09-27-2015 01:05 PM
ccdguy
09-19-2015 05:20 PM
MasterLanMan
09-13-2015 08:21 PM
Quick Reply: Clutch or what??
