roller 351?
Old 03-10-2007, 10:45 PM
w8less
w8less's Avatar
Default roller 351?
i am getting a 72 351w block for free. i know its not roller. are these blocks stronger than the rest like i have read? i want to convert it to roller; can it be a roller like my old 349? meaning could i put my old lunati nitrous cam in it(just an example)? i have read about people talking about retro-fit cams but i want to be a complete roller please help out.
what do i need to make it a roller motor i don't want it to be using the retro fit stuff where my cam selection is limited.
and please if you don't know or don't have personal experince don't guess
w8less is offline
Old 03-11-2007, 12:06 AM
w8less
w8less's Avatar
Default RE: roller 351?
anyone?
w8less is offline
Old 03-11-2007, 12:44 AM
vristang
vristang's Avatar
The only option is to use the link bar hyd-roller lifters for conversions.
They are expensive...
My Crane set was $475
But if you want to run a 302 based cam, this is the way to do it...
The pre 75 blocks are mildly stronger than 75 and later. How much stronger is constantly argued.
Lots of nitrous may still challenge the integrity of the 351w block.
Most say the safe limit is between 650-750, but there is more to it than hp level.
jason
vristang is offline
Old 03-11-2007, 12:51 AM
notch5oh
notch5oh's Avatar
talk to adder, he justgot a 71 block
notch5oh is offline
Old 03-11-2007, 04:18 AM
w8less
w8less's Avatar
do u have to get this also:
http://store.summitracing.com/partde...p;autoview=sku
so i just need a roller cam, lifters, and rr? also is there any maching to the block required?
w8less is offline
Old 03-11-2007, 05:04 AM
vristang
vristang's Avatar
ORIGINAL: Jasperstang308
That kit is useless for a non roller block, unless a small base circle cam is used...
Here is the Crane Hyd Roller conversion kit I will be using..
No machining, just drop the conversion lifters in with a 302 base circle cam...
vristang is offline
Old 03-12-2007, 01:41 AM
w8less
w8less's Avatar
well the guy sold the 351 out from under me. but i have a 302 thats a non roller can i use the same stuff to make it a roller or do i have to do nething different?
i am going to hit the junk yards tomorrow to look for a 351 still since thats what i really want but if i can't i still have something to fall back on
w8less is offline
Old 03-12-2007, 01:51 AM
r.barn
r.barn's Avatar
Look for one with a serial number that starts with F4 to F8
that will be a 1994-98 roller cam block, and will have the little screw holes
in the lifter valley for the hold down spyder.
r.barn is offline
Old 03-12-2007, 02:06 AM
w8less
w8less's Avatar
if i can't find one though would i still be able to use the same equipement that i would need to convert a 351 to a roller motor work for a 302?
w8less is offline
Old 03-12-2007, 02:14 AM
grabbem88
grabbem88's Avatar
there are tons of f-250's with roller block 351's in them...my block was tapped for the hold,and yes the crane's are pricy,but i'll never break them....it's one of those parts that will never have to be replaced...i'm using a 69 prepped block from dss....
grabbem88 is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
uedlose
09-30-2015 08:01 AM
Tyoung68
08-25-2015 04:31 AM
Mustangs of Illinois
08-22-2015 10:00 PM
89blueslug
08-10-2015 07:20 AM
Quick Reply: roller 351?
