Yes, another gear thread
ok....This thread is more about installation than gears. What I want to know is, those of you who have installed your own gears, was it a fuzzy warm experience for you or would you recommend actually taking it to a shop and have it done? I purchased a set of FRPP 4.10's along with the "install kit" from 50resto.com and am debating on tackling this myself or not. Any thoughts? Thanks!
J
J
RE: Yes, another gear thread
ORIGINAL: SN95Stang
ive heard from many ppl that they are not for beginners....im taking the gears and getting them intalled and having new clutch discs put in my trak lok all for 300....
$300 - $400 for a full overhaul (labor cost) is not a bad deal, anything less than that would fall in the TGTBT (Too Good To Be True) area, and quality of the work would be questionable.....do suggest you have them done, simply because it's not a "replace & torque" type of installation, and it requires some special measurement equipment.....check the procedure at http://www.angelfire.com/theforce/5o...5ohtech001.htm .......
jwog666
12-27-2021 08:09 PM
KingRando
10-02-2015 08:06 AM
