List your combo and track times/RWHP
Old 03-14-2007, 11:21 PM
FullAuto
FullAuto's Avatar
Default RE: List your combo and track times/RWHP
1988 LX coupe
393" Windsor
JE 13.5:1 pistons
Eagle 4340 crank and rods
Trick Flow Twisted Wedge heads
Victor Jr. intake
750 Holley
Comp XE 282HR
PA Supercomp C4 w/ transbrake
3.55s
NX Gemini Twin Stage 6
9.82 @ 137mph - and for sale for $9k if anyone is interested
1991 LX hatch
Dart block based 327"
8.5:1 custom Ross pistons
Scat 4340 crank and rods
Comp HR .544/.576 224/230 114
Performer RPM intake
75mm TB
80mm MAF
60lb injectors
Stock A9P untuned
Novi 2000 @ 13psi
Kooks LTs
3.73s
Air conditioning, power steering, stock clutch fan, full stock interior 100% street car driven 26 miles one way to work.
broke on dyno and made 602rwhp @ 5700rpm but never peaked
10.43 @ 131.5 on radials and 91 octane
FullAuto is offline
Old 03-15-2007, 02:54 AM
dimebag
dimebag's Avatar
1988 gt hatch, 5 speed
o/r h pipe
dumped 40 series flows
pro50 shifter
235/60/15 mickey thompson drag radials
stock everything else( w. aprox 200k miles on them(motor has only 80k)
14.2 at 98, 2.2 short time
dimebag is offline
Old 03-15-2007, 03:15 AM
grabbem88
grabbem88's Avatar
https://mustangforums.com/timeslips/
hope that helps
grabbem88 is offline
Old 03-15-2007, 02:35 PM
15austin
15austin's Avatar
Mods in the sig, 13.12 with 2.14 60', street tires. Dyno appointment for sunday at 4:00pm.
15austin is offline
Old 03-15-2007, 03:06 PM
blackstang2887
blackstang2887's Avatar
i ran a 16.9 before my additional 2 cylinder mod
blackstang2887 is offline
Old 03-15-2007, 07:01 PM
Mike 83 GLX
Mike 83 GLX's Avatar
'83 Mustang GLX converted to EFI 5.0L/T5/3.27 geared 8.8 rear.
Stock FMS crate shortblock
Edelbrock Performer heads/intake
F303 cam
Crane 1.6 RRs
70mm TB
75mm Bullet MAF/24# ijnectors
Crane ignition/coil
A9P computer tuned with TwEECer by me
MAC longtubes, Dr Gas x-pipe, MAC cat-back
BM185 electric fan
underdrive pullies
FFR upper and lower rear control arms
Kenny Brown Extreme Matrix subframe connectors
aluminum driveshaft
B&M Ripper shifter
190 lph pump
Aeromotive FPR
'95 Cobra 13" front discs, Mk VII rear discs
MT drag radials 255/50 16 for the strip
245/45ZR17 Goodyears on '00 GT wheels for street
SPEC stage 3 clutch kit---too much for a stock T5
Untuned, it dynoed at 288rwhp/306rwtq, but was still climbing when it hit the HI-6 rev limiter. I set it at 5400 messing around with it and forgot about it. It ran 13.0 @105 this way. Only got 2 passes that day.
After I messed with the tune a little, (mostly timing, MAF calibration, and shutting off emissions junk) it ran a 12.9 @ 109.3 first run taking it easy (2500rpm launch/bog). Second run, broke the input shaft when trying to launch higher. WC T5 only had 1000 miles on it, with 4 passes at the track.
Replaced the trans, but first gear only lasted a day on the street. Won't be fixing the T5 this time. Saving for something better.
It should be making a little over 300rwhp now, but I wont get to dyno again until after the turbo kit goes on.
Parts still sitting in garage:
31 spline Superior axles, 31 spline truck L/S diff, Garrett T04E14 turbo (.70/.84), 50mm wastegate, 50mm BOV, boost controller, 42# injectors, air-air intercooler, headers and pile of tubing, 75mm TB, spyder EFI intake, billet fuel rails, and a few other things. Bringing the car and parts to work tomorrow to start the build. Hoping for at least 450rwhp w/12psi. Can't do much more than that until I upgrade the block, trans, fuel sys, etc... Then its bigger turbo time.
Mike 83 GLX is offline
Old 03-15-2007, 07:03 PM
johnjr45
johnjr45's Avatar
mods in signature, no clue what track times are hopefully get it dyno tuned and run it this summer...
johnjr45 is offline
Old 03-15-2007, 08:37 PM
the new nos/man
I ♥ Acer
the new nos/man's Avatar
83gt 408w 11.5to1
eagle good stuff below
1000 cfm demon carb
victor jrs /super victor intake
cam solid roller spec's secret !
11.20/123 motor
10.09/138 200 shot
the new nos/man is offline
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
mdg
10-01-2015 07:04 AM
CS2007
Florida Regional Chapter
09-29-2015 12:06 PM
Quick Reply: List your combo and track times/RWHP
