Signs of fuel starvation
Old 03-15-2007, 04:16 PM
Pure5.0
Pure5.0's Avatar
Default Signs of fuel starvation
I know of some but just want to hear it from others. Around 2000RPM+ my car bogs really bad on some days and others its ok. How bad? Well lets just say I have a 0-60 in 10 secs 5.0mustang.
I don't know if it runs hot because of being lean because I have a coolant leak and have lots of air in my lines...causing spikes in the Tstat reading. So I can't judge by that. I also don't have any guages for monitoring my engine (a nono I know)
I am rulling on a fuel pump failure under load...but money is tight and don't want to purchase something that I didn't have to have at the moment.
Any ideas?
Pure5.0 is offline
Old 03-15-2007, 04:19 PM
drhoward
Penis Mod Erator
drhoward's Avatar
Default RE: Signs of fuel starvation
Fuel pumps aren't that expensive, what do your plugs look like they will give you a good indication if you are running lean
drhoward is offline
Old 03-15-2007, 04:27 PM
93must
93must's Avatar
You can buy a cheap fuel pres gauge from the auto parts store and screw it on to the shrader valve and see what it is doing!
93must is offline
Old 03-15-2007, 04:30 PM
Pure5.0
Pure5.0's Avatar
ORIGINAL: 93must
Shrader valve? Haven't heard that term yet....what is that?
Haven't pulled the plugs, but will soon now that you mention it.
Pure5.0 is offline
Old 03-15-2007, 04:35 PM
93must
93must's Avatar
It looks just like the valve that you put air in your tires with. Its on the fuel line where it drops down from the intake. If your looking at the motor it will be on the front left. It may have a black cap on it. Just unscrew the cap.
93must is offline
Old 03-15-2007, 05:05 PM
r.barn
r.barn's Avatar
could be any number of things.
I would check the baffle in the gas tank too.
sometimes they break loose and can cause strange fuel feed problems.
r.barn is offline
Old 03-15-2007, 06:17 PM
dimebag
dimebag's Avatar
whats ur fuel pressure suposed to be at?
dimebag is offline
Sixx
10-05-2015 07:36 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
Florida Regional Chapter
09-30-2015 08:04 PM
mrappe
09-26-2015 10:16 AM
Quick Reply: Signs of fuel starvation
