Engine cuts out?
Old 03-15-2007, 10:39 PM
90Lxstanger
90Lxstanger's Avatar
Default Engine cuts out?
Lately my engine has been acting up. It cuts and like its not getting fuel of something along the lines of that, i know its not missing on a cylinder or anything, plugs are 1 month old-new cap&rotor-about 3 months-wires 9mm FR-fairly new. Now its been happening since inter, but i thought it was just the cold, but now thats its warming up im kinda stumped-also it does this over bump(maybe baffle) but only happens on the way to work, never reeally notice on the way home which makes no sense
Sorry for the "book", thanks for the help.
90Lxstanger is offline
Old 03-15-2007, 10:52 PM
porkichu
porkichu's Avatar
Default RE: Engine cuts out?
i had the hot wire to the fuel pump rubbing the pump bracket inside the tank.she would just lose it all until i pulled off the road(bump)and it would fire right back up.it was when the wire finally welded itself to the bracket before i realized the pump had gone quiet.i hate to say it but you may need to hit a few more potholes or drop the tank if thatis happening.
porkichu is offline
Old 03-15-2007, 11:38 PM
90Lxstanger
ORIGINAL: porkichu
Well then engine doesnt die or anything it just for a second cuts out, like its not getting fuel, it could be something else, but thats a good idea with the wire but i think it coul be something ot do with sensors..........
Old 03-15-2007, 11:43 PM
notchbackmatt87
notchbackmatt87's Avatar
clogged cat?
notchbackmatt87 is offline
Old 03-16-2007, 12:50 AM
90Lxstanger
ORIGINAL: mustangmatt98
clogged cat?
No cats on the car.............basically like in the original post it does this over bump-which leads me to beleive its the pump_but it only does this in the mornings n the way to work at 6:00 am. doesnt do it as much in the afternoon,
Old 03-16-2007, 11:11 PM
reduceallpain
reduceallpain's Avatar
i got the same prob.... changed so much stuff nothing worked[:@]
reduceallpain is offline
Old 03-16-2007, 11:56 PM
frankbullitt
frankbullitt's Avatar
I got the same problem too. I happen just the other day. It didnt happen for a while but decided to happen yesterday. No matter how much gas pedal you give it it wont rev above about 2300 rpm.
frankbullitt is offline
Nick Oliver
10-17-2018 04:22 AM
TfcCDR
09-14-2015 12:08 PM
MusicCity615
09-12-2015 07:05 AM
Pyrate Dave
09-10-2015 07:30 PM
vintageaion
09-08-2015 10:45 AM
Quick Reply: Engine cuts out?
