sn95 steering pump
sn95 steering pump
ok im feeling kinda stupid rite now... i cant get this damn power steering pump off... is the pulley is held on with a bolt rite??? i have to take it out b4 i use a pulley puller rit?... if so how the hell do i get that bolt loose cuz it aint happening rite now... i need to get the drive side assecory braket off the bolt and head so i can take the head off... the pulley on the power steering pump is bolting the last screw i need to take out to slide hte braket off... i didnt wanna have to completely unhook the a/c or steering pump unless i had to... please give advice
RE: sn95 steering pump
I dont think my pulley was held on with a bolt, i just put a puller on it and yanked it part of the way off. Once you get it out a little bit you can get a wrench in behind it to undo the bolt. Undo the other 2 bolts and you should be able to pull the bracket forward a little and just either rest it on something or tie it to the side and you should be good.
jwog666
12-27-2021 08:09 PM
mrappe
09-26-2015 10:16 AM
