T5 to AOD swap, neutral safety and kickdown cable ??s
Ok, i swaped from t5 to a TCI streetfighter, I'm trying to figure out where my safety nuetral runs from, and what wires to use? I know it was before connected at the clutch pedal, but now i dont know what wires to use to reconnect onto the aod. Also could anyone post up a picture of how the kickdown cable connects to the TB on an EFI engine, or explain to me how to do this, I have the cable and the bracket needed for the TB, but i don't know how to hook it up! Any help would be great thank you!
RE: T5 to AOD swap, neutral safety and kickdown cable ??s
At one end of the TV cable (your kick down cable), there should be a block, that block pushes into one of the two holes in the bottom of your throttle body.
Matt's 95 Stang
10-05-2015 07:16 AM
