setup question? help
Old 03-25-2007, 05:52 PM
9165pt0
9165pt0's Avatar
Default setup question? help
hey guys i just want your opinion on if i should use a 65mm t/b or a 70mm t/b. i have some thumper ported gt40's with a 70mm opening gt40 intake and a 76mm maf. i know that the t/b size and maf size should be close, can i slide by with a 65mm or is it better to put on a 70mm.
9165pt0 is offline
Old 03-25-2007, 05:54 PM
HC_CrAzYHoRsE
Super Moderator
HC_CrAzYHoRsE's Avatar
Default RE: setup question? help
i thought the GT40's opening was 65mm like the cobra? ....in any case, a 65mm would be more than enough.
HC_CrAzYHoRsE is offline
Old 03-25-2007, 06:31 PM
9165pt0
9165pt0's Avatar
ok, what about the 76 mm maf tho, i heard the maf and t/b should be close. thats why i was wondering if i should get a 70mm t/b instead. will there much difference in power between the two? i just want the maf and t/b to work good together so if the 11mm difference wont hurt, its fine.
9165pt0 is offline
Old 03-25-2007, 07:01 PM
9165pt0
9165pt0's Avatar
anyone?
9165pt0 is offline
Old 03-25-2007, 07:08 PM
HC_CrAzYHoRsE
Super Moderator
ORIGINAL: 9165pt0
ideally you want about a 5mm difference, so if you already have the 76mm, might as well get the 70mm TB, but a 65mm and slightly smaller MAF would've been more than enoguh for your current setup.
jwog666
12-27-2021 08:09 PM
Lethaldosage423
10-19-2015 12:12 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: setup question? help
