Shakes at 1000 rpm idling and vibes at 4500 while driving b4 shifting.
Old 03-28-2007, 01:05 PM
omar50
omar50's Avatar
Default Shakes at 1000 rpm idling and vibes at 4500 while driving b4 shifting.
Ok guys I have a 94 gt convertible and for the last week or so when I have driven the car it seemed to have a vibration problem and now it is getting worse. When it idles it vibrates like something is out of balance, and when it hits a certain speed when driving it does the same. I would say the U - joints but since it does it at idleit cant be that. Do you guys have any idea before i take this thing to a mechanic and get raped. Thanks in advance-
Omar
omar50 is offline
Old 03-28-2007, 01:07 PM
nseoi
nseoi's Avatar
Default RE: Shakes at 1000 rpm idling and vibes at 4500 while driving b4 shifting.
could be a missfire. with the engine running remove one plug wire at a time and see if the engine sound changes. if it does then that one is fine. if one of them does not change the sound of the engine you are missfiring :O
nseoi is offline
Old 03-28-2007, 02:33 PM
94RedDevil
94RedDevil's Avatar
same thing is happening to me, i replaced the driveshaft w/ an aluminum one like the mech. told me to do but yea, wasnt it. I was thinkin that mine is the clutch b/c i know i need a new onebut hell, idk, i'm kinda new so i would be interested in what you guys determine.
94RedDevil is offline
Old 03-28-2007, 03:14 PM
92GreyGT
92GreyGT's Avatar
How many miles is on your engine? It may be the harmonic balancer. I would also look at the fan for any broken blades.
92GreyGT is offline
Old 03-28-2007, 04:26 PM
omar50
omar50's Avatar
hmm I did the spark plug trick already and same deal. How did u fix the harmonic balancer?
omar50 is offline
Old 03-28-2007, 04:59 PM
wine_maker
wine_maker's Avatar
man dont through money at it till you check things out
one easy thing to do is pull the belt>>>belts ifmore than one .
If the vib is gone check all things that the belt moves>
if the vib is steel there then check the H.B. bolt make sure it is tight:> the outer ring:> and the pully bolts
that hild it on>>>> AND on AND on >
just check thinge first >It is free for youto check things >
wine_maker is offline
Old 03-29-2007, 02:17 PM
omar50
omar50's Avatar
alright, I some one, Told me it can be the fly wheel balance. They may have came off.
Thanks guys
omar50 is offline
SonicStanGirl
06-04-2020 12:40 AM
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
Takeiteasee
08-27-2015 03:59 PM
deekum1627
10-09-2008 09:21 PM
Jazzer The Cat
21
08-04-2007 11:12 AM
Quick Reply: Shakes at 1000 rpm idling and vibes at 4500 while driving b4 shifting.
