Fuel Pump won't turn on. HELP PLEASE!!!
Old 12-11-2004, 04:10 PM
  #21
89MustangMan
89MustangMan's Avatar
Default RE: Fuel Pump won't turn on. HELP PLEASE!!!
hey guys, sorry i took so long to get back... this is what i have found out so far:
I have changed the computer...I put in an A9P, the origional was an A9L but i really don't think that's a big deal, i was looking on Ebay and more than one person claims it works with either a 5-spd of automatic.
I changed the fuel pump relay under the drivers seat. The only thing i don't understand is that they gave me one that has an extra pong in it, im not too sure if that matters or not.
I changed the relay under the pass side dash, it's right near the computer.
I have set and reset the enursha switch
I have changed the ignition switch
And finally i have even gone as far as taking out the gas tank to test the pump!
Is there something else this could possibly be? Its driving me crazy, when i was in the store buying new relays the guy pulled up some gas cut off switch? im not really too sure where that would be and if this would maybe be my problem.... Please help! thanks guys i really appreciate all of your imput...Nick
89MustangMan is offline
Old 12-11-2004, 04:45 PM
  #22
nemethjames1
nemethjames1's Avatar
the gas cut off switch is the inertia swtich, it cuts off power to the fuel pump.... my inertia switch went out on me, so i just took it out and ran it direct.... i hated having to reset it when i got sidways anyways
nemethjames1 is offline
Old 12-11-2004, 07:16 PM
  #23
roundman
roundman's Avatar
NOT TOO BRIGHT AN IDEA! now if you're in an accident the fuel pump can continue to run and the resulting fire could burn your *** up big time. the inertia shutoff switch if one of the few safety innovations that I don't have any problem with keeping on mine! Any car with an electric fuel pump is required to have one I believe by federal law. the switch is relative cheap if you value your life at all. replace it dude!
roundman is offline
Old 03-23-2007, 06:27 PM
  #24
mislead
mislead's Avatar
I got a quick question, my fuel pump relay won't turn on unless i ground the eec port test then it continues to run. Does this mean my eec is bad?
mislead is offline
Old 03-23-2007, 06:30 PM
  #25
88BlueGT
88BlueGT's Avatar
ORIGINAL: roundman
see if this helps you out any
[IMG]local://upfiles/5542/A43131172CAD47EDB04E0AE0FCEEDF5A.jpg[/IMG]
Is that chart 93 specific since its SEFI?
88BlueGT is offline
Old 03-23-2007, 06:34 PM
  #26
LTnone
LTnone's Avatar
LTnone is offline
Old 02-16-2008, 04:22 PM
  #27
pimpinstang1
pimpinstang1's Avatar
i need help too!!!!!!!!! wont start no noise from the pump!!!
pimpinstang1 is offline
Old 02-16-2008, 04:42 PM
  #28
86 5.0L
86 5.0L's Avatar
check the reset button in the trunk/hatch under the back panel
then the relay under the drivers seat should click once when you turn the key to ignition
86 5.0L is offline
Nurdyguy
02-18-2024 07:58 PM
raleigh05GTO
09-04-2015 07:09 AM
5.0 kevo
09-03-2015 06:24 PM
SYNY5TER
09-02-2015 01:35 AM
Quick Reply: Fuel Pump won't turn on. HELP PLEASE!!!
