if everything sounds good ill order now
so as soon as i get an answer from you guys im gonna order Novi 1000 and 70 mm t/b ford racing 30 lb Injectors 76 mm maf
is this too much for my set up you see in my sigg do i wanna go with smaller anything or does everything look good?
RE: if everything sounds good ill order now
i was gonna order this but its say use 65 mm tb for stock manifold whys that
http://cgi.ebay.com/ebaymotors/86-93...29754794QQrdZ1
huh blow thru? i just spent 2700 bucks nooooo hope i didnt get the wrong stuff http://cgi.ebay.com/ebaymotors/ws/eB...:IT&ih=016
ORIGINAL: mattdel
actually i think u will need a blow thru MAF for S/C's
The reason it says to use a 65mm tb with the stock manifold is because the opening in the manifold is small (close to 65mm). You can get the 70mm tb for now as long as you are planning on upgrading the manifold at some point, otherwise you should get the 65mm tb.
Diode Dynamics
28
05-26-2022 12:02 PM
Faolan65
Arizona Regional Chapter
08-25-2015 09:24 AM
