gear quetsion
Old 06-21-2007, 05:57 PM
lebo89stang
lebo89stang's Avatar
Default gear quetsion
i just bought a 89 gt. how can i tell what gears are in it. it is a 5.speed. i dont want to put gears in it if the guy who had it before me did it already.
lebo89stang is offline
Old 06-21-2007, 06:02 PM
dimebag
dimebag's Avatar
Default RE: gear quetsion
lift the back end... rotate the tire... count tire rotations/driveshaft rotations.... or... use the search feature...
dimebag is offline
Old 06-21-2007, 06:04 PM
mattdel
mattdel's Avatar
jack up the rear end, and support on jack stands.
place the transmission in neutral.
make an alignment mark on the right rear tire, and on the driveshaft.
spin the right rear tire exactly one time, using the mark you made as a reference.
while spinning the tire, count how many times the driveshaft turns, also referencing the mark you made on the driveshaft.
just under 3 spins, 2:73's, just over 3 spins, 3:08 or 3:27's, etc etc
mattdel is offline
Old 06-21-2007, 06:20 PM
lebo89stang
cool. thanks alot guys you are a big help.
Old 06-21-2007, 07:43 PM
nitrous_bob
nitrous_bob's Avatar
yup, thats how you know for sure, but what was in it stock ?
read the door tag "ax" code
m=2.73
z=3.08
e=3.27 (aod's only)
nitrous_bob is offline
Thunderball
15
11-22-2015 11:49 PM
Bokeo
10-10-2015 08:28 PM
KingRando
10-02-2015 08:06 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Quick Reply: gear quetsion
