AC not turning on
RE: AC not turning on
ORIGINAL: 85GTsleeper
a/c eliminator kit
a/c eliminator kit
Could be your low on freon take it in for an A/C check if your still R-12 be prepared to pay $$$$$$ for a fix. If your converted to R-134 just pick up a can with charging hose from Checker or Auto Zone. they have plenty of them there in Gilbert. I just moved from there I hope for the last time!!
ORIGINAL: raven_ghostwolf
Trust me summer time in AZ you want that A/C!
a/c eliminator kit
a/c eliminator kit
yes, the system must be evacuated before you can remove the pressure switch.
test it first.
like stated above, just run a jumper wire between the terminals in the wiring connector, if your problem goes away, you've found the culprit.
test it first.
ORIGINAL: mattdel
test it first.
test it first.
lincolnshibuya
12-08-2015 04:37 PM
breaking
10-02-2015 01:27 PM
logan409
09-26-2015 07:43 PM
