engine building?
Old 06-29-2007, 07:09 AM
mustang90!
mustang90!'s Avatar
Default engine building?
I have a 306 with ross pistons and trick flow stage one camand was 10.1 comp with gt40p heads, but plan on putting afr 165 heads on it. i was wondering if anyone had a supercharger for sale.with 10lbsof boost should i o ring the heads and what compression ratio i would be running with the 165 with 60cc i think. would 10lbs be too much if the comp ratio was close to 10.1. any other info would be greatly appreciated
mustang90! is offline
Old 06-29-2007, 10:26 AM
94StinkinLincoln
94StinkinLincoln's Avatar
Default RE: engine building?
with 10:1 u aint boostin on pump gas. u need to get it down to at very least 9:1 with pump gas
94StinkinLincoln is offline
Old 06-30-2007, 01:11 AM
mustang90!
mustang90!'s Avatar
what if i used e85 with the higher octane and a mr freeze from anderson to come on at 4000 to 6000. i dont want to rev past six
Old 06-30-2007, 02:51 AM
67mustang302
67mustang302's Avatar
You could prollydo it with e85, but your mileage will suck hard, especially if you go wot regularly. For pump gas 9.5:1 is about the max you can run with low boost(6-7lbs) if you have a good build/tune. But 9.0:1 or lower is prefered
67mustang302 is offline
Old 06-30-2007, 08:25 AM
mustang90!
mustang90!'s Avatar
i could care less about gas mileage. it wont be a daily driver just some afternoon fun once in a while. anyway to run 10lbs thats the max i would try and go with that compor what about nitrous. i know the stock comp was 9.1 and i had a 100 shot on it before, will that one point really make a difference and what does anyone reccomend, nitrous or blower 10lbs or a 100 shot. if 10lbs then how can i get the car to run without blowing up. what octane should be used retard ignition how many degreesor if i used the nitrous it would be a wet shot so it should run good but worried about blowing myself up with that one point. any response would be great.
Nick Oliver
10-17-2018 04:22 AM
TfcCDR
09-14-2015 12:08 PM
MusicCity615
09-12-2015 07:05 AM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: engine building?
