do i need caster/camber w/ 4cyl springs???
Old 07-01-2007, 02:12 AM
Vader87
Vader87's Avatar
Default RE: do i need caster/camber w/ 4cyl springs???
Do the 4 cyl springs actually lower your car? I had an original 4cyl to 302 motor change over notch & my 4 cyl.springs in the car didnt lower the car or have that appearance, in fact the front end actually set higher after the motor conversion. I am just curious?
Vader87 is offline
Old 07-01-2007, 02:13 AM
dimebag
dimebag's Avatar
mine is SLIGHTLY lower
dimebag is offline
Old 07-01-2007, 05:03 AM
raven_ghostwolf
raven_ghostwolf's Avatar
Front springs for a fox 4 cyl
1979 - 92 = 370 lb/in constant rate.
1993 are 400 lb/in constant rate
Handling/GT/heavy duty.
1979 = 395 lb/in constant rate, TRX 425 lb/in constant rate
1980 - 81 =370 lb/in constant rate, TRX 395 lb/in constant rate
1982 = 395 lb/in constant rate, TRX 410 lb/in constant rate
1983 - 84 including TRX = 410 lb/in constant rate.
1984 1/2 - 86 = 425 - 525 lb/in variable rate
1987 - 93 including 93 Cobra = 425 - 530 lb/in variable rate
1993 Cobra R = 750 - 850 lb/in variable rate
And to complete the info;
Rear springs for fox 4 cyl
1979 - 84 1/2 = 160 lb/in constant rate
1984 1/2 - 93 = 160 lb/in constant rate
1979 - 84 = 160 lb/in constant rate, TRX 175 lb/in constant rate
1984 1/2 - 93 = 200 - 300 lb/in variable rate
1993 Cobra = 160 lb/in constant rate
1993 Cobra R = 240 - 260 lb/in variable rate
raven_ghostwolf is offline
Old 07-01-2007, 04:55 PM
ford91mustang
ford91mustang's Avatar
should i leave the isolators on or take them off when i install the 4cyl springs???
ford91mustang is offline
Old 07-03-2007, 01:50 PM
Jfsram
Jfsram's Avatar
It all depends on how much camber you are after.
Lowered Mustangs gain negative camber and that is definately hard on wide tire for wear but negative camber actually increases cornering. Especially at low speeds.
Jfsram is offline
7upedition
12-02-2006 03:57 AM
PushinTheLimit
11-15-2006 03:55 AM
submit
05-01-2006 11:26 PM
4ZZS
09-27-2005 05:08 AM
TBlake
SVT Forums
02-08-2005 12:57 PM
Quick Reply: do i need caster/camber w/ 4cyl springs???
