front brakes
RE: front brakes
yeah make sure you used pad shims yeah the ones that come in the box with a decent set of pads not the cheap as_ ones that you buy at autozone for 10.99 the cheap ones are cheap for a reason they don't comwwith the required hardware!!! make sure you are definately hearing a brake noise!!
RE: front brakes
ORIGINAL: mjr46
RE: front brakes
ORIGINAL: ratrodf1
i'm sure its a brake rattle because when i ride the brakes you can't hear it . where can i get some of the pad shims ?
Get some anti-squeal goo that's usually in blue or orange, take the clips out and and put a very LIGHT coating of the goo on the back of the clip that engages the calipers, not the pads. Then get some anti-sieze or light grease and put that on the surface of the clip that engages the pad guides.
09-16-2015 07:53 PM
09-08-2015 11:50 AM
