brass or copper shavings???
Old 07-09-2007, 09:20 PM
1fast5.0
1fast5.0's Avatar
Default brass or copper shavings???
ok i had to change my oil pump and i took the pan off and there was little copper or brass shavings not to sure what it isiam thinking that one of my bearings is bad ? if i remove all the lower caps to check the bearings would i be able to tell if its bad on the top/would the bottom bearing show some wear? i only put like 50 miles on this car since motor was builtand i think its about to be riped apart again.can anyone tell me what else would make some little copper or brass shavings so i can try to figure out what to do.iam about to just put it back toghether and see what happens if it blows then time for a 351!!
1fast5.0 is offline
Old 07-09-2007, 09:23 PM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: brass or copper shavings???
50 miles on a rebuild and your worried about metal shavings???? its completely normal... its still breaking in
AdderMk2 is offline
Old 07-09-2007, 09:27 PM
1fast5.0
1fast5.0's Avatar
ya but there was some pretty big pieces!not just little shavings
1fast5.0 is offline
Old 07-09-2007, 09:47 PM
silver91gt
silver91gt's Avatar
bearings, did you prime the oil pump right before you started the motor?
silver91gt is offline
KingRando
10-02-2015 08:06 AM
tramphardrocker
09-13-2015 08:56 PM
TfcCDR
09-12-2015 04:13 PM
mustangchef
09-04-2015 08:08 PM
Quick Reply: brass or copper shavings???
