overheating help
Old 07-09-2007, 11:43 PM
droptopfoxgt
droptopfoxgt's Avatar
Default overheating help
hey my buddy has a 95 5.0 and it overheated on his way TO the beach and he drove all the way to the beach and home just adding water every few miles not letting it cool. the water pump works, its a new t-stat, the fan works, the rad is new, and we are stumped. it has oil pressure and the oil in it is not milky or off color and has no particles in it. any help would be great thanks
droptopfoxgt is offline
Old 07-09-2007, 11:47 PM
mattdel
mattdel's Avatar
Default RE: overheating help
how do you know the water pump is good?
and with those new parts, it could be air.
mattdel is offline
Old 07-10-2007, 11:49 PM
droptopfoxgt
we ran the motor with the rad cap off and the coolant was flowing. what do you mean by air? like outside temp?
Old 07-10-2007, 11:57 PM
Ninety5five0
Ninety5five0's Avatar
The thermostat could be bad even tho its new. Feel the upper and lower rad. hoses when the car starts getting hot and see if its flowing or not.
Ninety5five0 is offline
Old 07-11-2007, 12:00 AM
iceman89gt
iceman89gt's Avatar
no apparent leaks any where droptop? are you sure its the correct thermostat, also check the thermostat for sticking. if you pull the thermostat out and run it for a while and it doesnt get hot then it could be sticking intermintently. at worst it could be a burned piston. the way to tell this is to pull the spark plugs out and turn it over, if water shoots out the spark plug hole then its a burned piston, or you can pull the radiator cap with the plugs out and bubbling will indicate this also.
iceman89gt is offline
Old 07-11-2007, 12:28 AM
droptopfoxgt
yea its the right t-stat and my buddie boiled it till it opened on the stove to see if it worked. i think he is gonna just take it somewhere. but ill tell him to try the burnt piston stuff so thnx alot guys
Old 07-11-2007, 06:24 AM
blky2kz
blky2kz's Avatar
It is possible it could have a blown head gasket even tho water and oil arent mixing. I had a blown head gasket in mine. The piston was actually forcing the cumbustion into the water jacket and making it overheat.
blky2kz is offline
BOB ROME
07-26-2023 01:54 PM
mungodrums
09-29-2015 09:18 PM
yourmom6990
09-14-2015 10:52 PM
MusicCity615
09-12-2015 07:05 AM
96stang3.8
09-10-2015 06:42 AM
Quick Reply: overheating help
