Turn Signal Problem! HELP!
I have an 88 GT for some reason all of a sudden it keeps popping the fuse to the turn signals/ low fluid lights that pop on when needed. Now first thing I thought was a short because I can replace the fuse and drive down the road without having a problem. When out of no where it will pop after working flawlessly for the whole drive. Also I can hit the hazard switch and they both work perfect. Now I realize its a separate fuse but I was trying to weed out having a bad signal switch in itself. Nonetheless I am going through fuses like water here so if anyone has any input whatsoever please dont hesitate to help. Thanks
RE: Turn Signal Problem! HELP!
If you are going through fuses you have a short. If its a turn signal problem, start with the easy things to look for before chasing down a worn wire. Look at the wires by the turn signal lights up front. It's hard to trace down shorts without being there...
musnicki
09-23-2015 07:11 AM
