c4 or aod
Old 08-05-2007, 05:19 AM
86GT 93LX
86GT 93LX's Avatar
Default RE: c4 or aod
c-4 they can be built cheaper and made verystrong
86GT 93LX is offline
Old 08-05-2007, 07:06 AM
nitrous_bob
nitrous_bob's Avatar
3 options for 400hp automatic car
1) c4
2) c4
or 3) c4
i hate aods, had no luck at all w/ them, went through 4 of them on 2 diff cars
rpms won't be bad, your t5 in 4th gear will be the same as a c4 in 3rd, both are 1:1
99% of all final drive ratios in non-od cars is 1:1 , or the gear b4 od in anything else
look at your door tag for the gear you have under "ax" m=2.73, z=3.08, e=3.27(aod only)
nitrous_bob is offline
Old 08-05-2007, 07:20 AM
86GT 93LX
86GT 93LX's Avatar
plus one
Old 08-05-2007, 09:30 AM
92hatchLX
92hatchLX's Avatar
Just because one person has a ****ty transmission builder or doesn't feel like properly adjusting his TV cable,doesn't mean that the AOD is a bad transmission. There are plenty of 400 rwhp +cars running around with AODs. Remember that the converter doesn't lock up in a C4 which = a LOT more heat. Look around corral in the turbo section, there's a guy pushing 730 rwhp through an AOD. But the C4 on the other hand is slightly cheaper. But which would you rather have? An inexpensive transmission with no converter lock up or 4th gear, or something that's a lot more streetable and gets ALOT better gas mileage that's alittle more expensive.
92hatchLX is offline
Ryan Fitzpatrick
09-14-2015 02:21 AM
CarrieS
09-01-2015 01:00 PM
TAC_Sisco
01-08-2004 06:33 AM
89 GT
11-18-2003 03:24 PM
MustangGT95
07-31-2003 02:56 AM
Quick Reply: c4 or aod
