Another h pipe quesiton, what is.....
Old 07-31-2007, 07:12 PM
BlackBetty93GT
BlackBetty93GT's Avatar
Default Another h pipe quesiton, what is.....
on the stock h pipe, there is a little tube that connects to each side of the h pipe, right before the cross over in the h pipe...the little tubes runs from down there all the way up into the engine bay somewhere....what is that? Do i need that on an off road mid pipe?
BlackBetty93GT is offline
Old 07-31-2007, 07:15 PM
Boss_Hotrod
Boss_Hotrod's Avatar
Default RE: Another h pipe quesiton, what is.....
Its the fresh air pipe. The smog pump pumps fresh air into those to help the exhaust gases flow. An off-road pipe doesnt need it since the gases do not have to pass through a cat.
Boss_Hotrod is offline
Old 07-31-2007, 07:17 PM
BlackBetty93GT
aight, thanks
Old 07-31-2007, 08:33 PM
94Blk5.0
94Blk5.0's Avatar
Most off road pipesshould havethe hook-ups for all emission equipment, like the smop pump.
94Blk5.0 is offline
Old 07-31-2007, 08:42 PM
stang8689
stang8689's Avatar
ditch that junk
stang8689 is offline
Old 07-31-2007, 08:44 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Better leave it in tact, you have emissions don't you. Mine is connected and functional.
PRO50SC is offline
Old 07-31-2007, 08:57 PM
94Blk5.0
94Blk5.0's Avatar
Hook it up right, if you don't then you have to do something with the pump, and honestly you are not going to gain anything by removng it.
94Blk5.0 is offline
Old 07-31-2007, 09:53 PM
creekrat
creekrat's Avatar
Yea, better check what you need for emissions before you cut and ditch anything you may regret later on!
creekrat is offline
Old 07-31-2007, 11:12 PM
BlackBetty93GT
well here lies the problem, the off road h pipe i bought used for $25 has the hole for it welded shut
09-24-2015 09:18 PM
trashxtrash
09-20-2015 10:49 PM
Big Al's 03
09-16-2015 07:31 PM
BrantleyS550
09-14-2015 04:18 PM
wawagner82
09-13-2015 09:02 AM
Quick Reply: Another h pipe quesiton, what is.....
