'95 Boss Shinoda charging problems...
Old 08-04-2007, 12:20 AM
74Grabber
74Grabber's Avatar
Default '95 Boss Shinoda charging problems...
I have a 1995 Boss Shinoda Mustang. The car has a '94 Cobra motor in it, that has about 90,000 on it, and a '92 GT transmission. The body of the car itself, along with all the wiring has 229,000 miles on it. (I know, I know... *** load of miles, that's what everyone says... You'd never guess it by looking at the car though, I keep it nice.) The car has underdrive pulleys, cold air intake with K&N filter, ported upper and lower intake with ported GT40P Explorer heads, slightly larger injectors, Flow Masters with X pipe, and a 3:73 rearend from a '97 GT in it. It started a couple of weeks ago, I was on my way home from work, getting on the interstate, and got on it pretty hard through 3rd gear, goofing around with this guy in a Scion TC.
I look down and the Alternator gauge was going crazy and the Check Engine, Battery, Anti-Lock and Air Bag idiot lights were all randomly turning on and off. I thought that was very odd, but once on the interstate, everything settled back down to normal, and remained normal the rest of the 61 mile trip home. So I didn't think much of it.
I get in the next morning to go to work, turn the key, and all hear is "click". Dead battery. I jump it off, and notice that the Alternator gauge is not showing any charge. I rev it up, and the gauge goes to the uppper half of the scale. So basically, at idle, the car was not charing at all. But anywhere above 2,500 RPM, and it charges fine. So I managed to get by for two weeks with it like that, just making sure to try to keep it above 2,500 RPM most of the time.
I went and picked up a new alternantor for the car tonight. I installed it and started the car up. Everything looked fine, car was charging well at idle with lights, A/C and everything on. I shut the car off, picked my tools up, and shut the hood. Started it back up, nothing... the car is not charging at all now. I drove it down the street and back, no change. Dosen't matter how high you rev it now, it does not charge at all. Battery was dead again when I got back to my house.
What is there besides the alternator that could cause the car not to charge? Isn't the regulator on the alternator itself? Any help would be appreciated. Sorry for the long *** post, just trying to be thorough.
74Grabber is offline
Old 08-04-2007, 07:53 AM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: '95 Boss Shinoda charging problems...
start checking your fusible links, and test for voltage AT the alternator itself. sometimes remanufactured starters are just junk
AdderMk2 is offline
Old 08-04-2007, 02:06 PM
TBird232ci
TBird232ci's Avatar
Sometimes a dead battery just wont charge.
TBird232ci is offline
Old 08-04-2007, 03:44 PM
ttocs
ttocs's Avatar
check your grounds. I had to re-do mine as the factory ground sucks, right next to the battery.
ttocs is offline
Old 08-06-2007, 11:50 AM
74Grabber
74Grabber's Avatar
Turned out to be the three wire plug that plugs into the alternator. The part that "clips" on when you plug it into the alternator was broke off, so it could just vibrate loose. I went to the junkyard and cut one off another car there, soldered and shrink wrapped it on my car, and all is well now.
Thanks for the help.
PaulH2
20
01-31-2016 09:48 AM
bradleyb
11-27-2015 07:50 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
UrS4
09-30-2015 10:13 AM
Quick Reply: '95 Boss Shinoda charging problems...
