Pics of parts of the motor. (Previous question)
RE: Pics of parts of the motor. (Previous question)
To add, all the smog equipment was removed. It still uses the MAF and MAP, but the EGR isn't hooked with a vacuum line. Not sure about the O2 sensors. I mean shouldn't all this be connected or NONE be connected, not mix and match?
EGR does not run off of manifold vacuum directly. It is controlled by the EGR vacuum regulator mounted on the back side of the passenger shock tower. The line with the bolt in it is supposed to run down to the charcoal canister purge solenoid on the passenger side frame rail right behind the radiator.
