is it possible to weld oil pan?
Old 08-06-2007, 05:39 PM
redb18b1eg6
redb18b1eg6's Avatar
Default is it possible to weld oil pan?
my timing chain broke and some how it put a whole in mhy oil pan and im really low on money right now i just bought the timing cahin water pump gasket and oil pan gasket and im just trying to find out if welding my oil pan is safe and reliable of if i should just wait until i have the mon ey for a new one
redb18b1eg6 is offline
Old 08-06-2007, 05:43 PM
TwotoneVert
TwotoneVert's Avatar
Default RE: is it possible to weld oil pan?
Where is the hole? If you could weld a plate over it, it would work for now, but that is sure enough southern engineering. I would hate to ruin a good engine over something like that. Are you sure you cant find a used one somewhere?
TwotoneVert is offline
Old 08-06-2007, 06:11 PM
ALMOST STOCK
ALMOST STOCK's Avatar
Yes it can be welded, as long as it doesn't warp and cause an oil leak.
ALMOST STOCK is offline
Old 08-06-2007, 06:31 PM
tinman
tinman's Avatar
IMHO, the worst part is going to be getting the old pan off your car.
My pan on my racer has been welded and its no big deal.
Have the inside/outside of the pan beyond clean before any welding is attempted.
Good luck..........
tinman is offline
Old 08-06-2007, 06:35 PM
jakeachy
jakeachy's Avatar
it would have to be a low amp weld, i would do 45 amp 6011. 6013 will put too much bead on(heat) and probably wont be able to root nicely because of the oil residue.
jakeachy is offline
Old 08-06-2007, 06:41 PM
tinman
tinman's Avatar
I took mine to work and had a guy that real good with a MIG welder do it for me..........
Dunno what his set-up was was but 45 amps would be about OK...
tinman is offline
Old 08-06-2007, 07:14 PM
creekrat
creekrat's Avatar
Yes, you can weld it, preferably out of the car tho! I wouldn't suggest welding it on the car, too many dangers in and around there to be welding. IMO
creekrat is offline
Old 08-06-2007, 07:19 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
play it safe dude!!! jack the engine up and remove the oil pan and take off the pan and go get it welded!! if your chain broke when you get the new chain back on I 'd do a compression test and or cylinder leakage test to make sure you don't have any bent valves[&:]
mjr46 is offline
Old 08-06-2007, 07:36 PM
my77stang
my77stang's Avatar
i'll be welding mine back up =)
as stated, take it off, make sure its all carb cleaned up around where the welding is happening so the metal is CLEAN.
if you weld on the vehicle you can easily end up with slag in the pan, and ONE single bead of slag or splatter will destroy your motor (i've seen it happen before at work)
my77stang is offline
b8checker
10-08-2015 12:55 PM
UrS4
10-03-2015 06:23 AM
jrrhd73must
10-02-2015 09:17 PM
b8checker
09-30-2015 07:11 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: is it possible to weld oil pan?
