The perfect engine t-stat?
Old 08-13-2007, 12:30 AM
1985lxfiveoh
1985lxfiveoh's Avatar
Default The perfect engine t-stat?
I have a 1985 lx notch 5.0. I have edelbrock intake with 600 holley. The rest is bone stock. Whatthermostat should I put in it? right now it running too hot for DD. At what tempdoes the eninge perform at its best?
thanks.
mike
1985lxfiveoh is offline
Old 08-13-2007, 12:42 AM
86 5.0L
86 5.0L's Avatar
Default RE: The perfect engine t-stat?
200* is optimum temp, a 180* or 190* stat is best
86 5.0L is offline
Old 08-13-2007, 01:09 AM
OnyxCobra
OnyxCobra's Avatar
I went with a 180° to keep it a lil cooler...
OnyxCobra is offline
Old 08-13-2007, 11:03 AM
luckythirteen13
luckythirteen13's Avatar
stock thermostat is 195 but itll make more power with a 180. not a huge amount but the cooler you can get parts (within reason) the longer they last and the more power the motor will make
luckythirteen13 is offline
Old 08-13-2007, 09:53 PM
1985lxfiveoh
I want to thank all of you for your responses, I think I will go with a 180 just to cool it down.
Thanks Again!
Mike
Old 08-13-2007, 09:56 PM
mattdel
mattdel's Avatar
since you are carbed you could go 160 if you wanted to, but only really if you run the **** out of it
mattdel is offline
Nick Oliver
10-17-2018 04:22 AM
PullTab
10-30-2015 08:46 AM
StalkerGT
09-25-2015 02:41 PM
09-10-2015 08:39 PM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: The perfect engine t-stat?
