tire size?
tire size?
ok so im setting a car up to run at the track with 4.30 gears a built AOD and either a 347...347 with nitrouse...or a 347 with a turbo (confused right now). Would i be able to fit a 10.5" by 28" tire under the car? (its a 92 5.0 hatch) or is there another size i should be looking at
RE: tire size?
will it rev ?
i would start w/ 26 X 10 1/2" you'll lose a lot of gear w/ the 28's and aod NEEDS gear
if the r's are too high on the 26's then go 28
26's will easily fit, remove or reverse the quad shocks end for end , if the tire digs too hard and rubs on the fenderwell, put a bag on the right side w/ about 8 psi and it will not anymore
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-08-2015 06:25 PM
M3hunter
09-05-2015 03:42 PM
