CAN I REPLACE THE VOLTAGE REGULATOR IN MY 86 GT GAUGE CLUSTER????
The oil pressure, water temp, and the fuel guages always screw up on me, could it be the voltage regulator in the cluster?? and can it be replaced if anybody had a similar problem did it fix it?? The oil pressure gauge will almost peg all the way to high and sticks i have to tap on the gauge and then it will fall to the middle in normal. Every time i drive the car the water temp and fuel gauge will peg at the same time but intermittently. If anybody has a picture if this regulator is replaceable so i know what i'm looking for.
RE: CAN I REPLACE THE VOLTAGE REGULATOR IN MY 86 GT GAUGE CLUSTER????
Yeah, you can replace it
http://www.autozone.com/R,APP1466279...ductDetail.htm
zanemoseley
09-06-2015 12:58 PM
