Ok, she is still stumbling for some reason.
I have checked everything I can think of and nothing is broke, burnt, loose, or missing. I am going to replace the plugs, never have done that, wires, dizzy cap and rotor, and fuel filter. If that does not do it, I guess I will have to take it to my mechanic. Question, can I connect a fuel pressure gauge to the test port on the fuel line? I thought the test port was on the rail, but mine is located on the return line just behind the alternator. Is this right? Any ideas or comments appreciated! I would like to leave the gauge installed and mount it to the firewall. Anyone else have a pressure gauge under the hood? I know the regulator is not that old, maybe 3 years, and dont want to replace that if I dont have too.
RE: Ok, she is still stumbling for some reason.
I guess your talking about the schrader valve on the fuel line,yes you can use it.that where i have my gauge andmy fuel feed line for then20.you might also want to repalce coil unless you already have and also the pick up inside the distributor
[IMG]local://upfiles/29615/D921115D3F0244FC9BC951B29892944F.jpg[/IMG]
Thanks Adder, I am not sure about that one. LT, it seems to only want to stumble when cruising at a level rpm, like in 5th gear at 1k, or 4th gear staying at 45 mph, etc.
TfcCDR
09-14-2015 12:08 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
DrunknRuckus
08-23-2015 10:05 AM
