EGR plate
Old 08-26-2007, 06:59 PM
getafewlives
getafewlives's Avatar
Default RE: EGR plate
Lucky you, I hate that light. Whenever it comes on I have to fix it. It bothers me to know my car is sick
getafewlives is offline
Old 08-26-2007, 08:27 PM
5.0stanger
5.0stanger's Avatar
I have a code 33 with my simulator. I thought that without code 33, it would be more likely to get a computer controlled spark advance and cause detonation.....not really sure, just what i heard.
5.0stanger is offline
Old 08-26-2007, 08:48 PM
Joel5.0
Joel5.0's Avatar
ORIGINAL: 5.0stanger
If you allow the valve to work normally, w/out any exhaust gases being injected into the combustion chambers, the EEC will add spark advance to compensate for the inert gases based on the EVP rate of change, and cause detonation......any EGR failure code (31, 32, 33, 34, 35)...will cause the system to bypass/delete the EGR function, shut it down, and not add the EGR based spark advance "addition" to the spark tables.
Joel5.0 is offline
Old 08-26-2007, 08:54 PM
5.0stanger
5.0stanger's Avatar
So since I have a speed density car without a CEL, I didn't need a simulator? Hmmm. Lots of bad info being spread around but Joel knows his stuff.
Old 08-26-2007, 09:00 PM
stang8689
stang8689's Avatar
Mine runs better with the vacuum blocked off,I guess i might as well get rid of it
stang8689 is offline
Old 08-26-2007, 09:03 PM
Joel5.0
Joel5.0's Avatar
So since I have a speed density car without a CEL, I didn't need a simulator? Hmmm. Lots of bad info being spread around.
[sm=exactly.gif]....
Joel5.0 is offline
Old 08-26-2007, 10:45 PM
RNCCMotors
RNCCMotors's Avatar
Thanks for the input guys, I will jump on getting this taken care of tomorrow. On another note, if you're standing in front of the car, behind the passenger side strut tower there is a series of vaccum lines/sensors. I have 2 white hard plastic vaccum lines that are broken, are these EGR related?
RNCCMotors is offline
Old 08-26-2007, 11:10 PM
blahman20
blahman20's Avatar
You can take the EGR Valve right off?? and do what? block it with a plate...I guess i'll leave it on there for now, because I have an e-test coming up, but my car is idling weird and I was thinking that might be the problem, so maybe i'll just eliminate it.
blahman20 is offline
Explosive
10-02-2015 07:45 AM
mdg
10-01-2015 07:04 AM
winner99
09-30-2015 07:04 PM
maestro1024
09-21-2015 02:40 PM
TfcCDR
09-14-2015 12:08 PM
Quick Reply: EGR plate
