your opinion on air/fuel ratio guage.
RE: your opinion on air/fuel ratio guage.
ORIGINAL: 94StinkinLincoln
aem wideband guage and sensor, you can see your a/f ratio w/ the guage and hook the tweecer up and see it in there also with ur datalog.
btw sam do you kno how to make the adjustments so that tweecer sees the same a/f ratio as ur wideband, i kno through wire resistance the #'s change. i have the aem guage and it has a bosch sensor.
ORIGINAL: mnile9127
I'm dealing with the same problem. You have to get a wideband transfer curve for that AEM.
Then load that curve to Cal Con. Good luck trying to find the transfer curve. If you find one
let me know. But open Cal Con , click the setup tab, under the EVP signal transfer click AEM or
PLX thats what I use. then in the second window click AFR.
5v 20.0
4v 18.0
3v 16.0
2v 14.0
1v 12.0
0v 10.0
It's just a straight linear transfer.
when you go WOT with a narrow band O2 gauge it will tell you if you're lean/rich or w/e, but it doesn't give you the number and it might not be as accurate.
ORIGINAL: OnyxCobra
Now lets say you floor it and go WOT. Lets also say that while in WOT, you have an A/F ratio of 14.0:1. Well that's really lean for WOT and you can run into some major problems. Yet the narowband gauge will tell you that you are rich. So you can end up blowing your engine all the hell because you are too lean, but the wideband is telling you you are rich.
That's just part of teh reason that it is useless.
uberstang1
09-20-2015 06:42 PM
