temperature coolant sensor...
Old 08-31-2007, 12:37 PM
DoctorD415
DoctorD415's Avatar
Default temperature coolant sensor...
Just got my 85 Mustang and still trying to figure things out. The temperature gauge as of now isnt working. I've checked the wire andmade sure its working and grounded it to make sure the gauge is working. This leaves the sensoir itself going into the manifold thelikely culprit, but i can't track one down. The parts store cant seem to find the right one when i go there. It has an Edelbrock Performer RPM intake manifold. How can i track this sensor down, because i need one badly?
DoctorD415 is offline
Old 08-31-2007, 12:39 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
Default RE: temperature coolant sensor...
go aftermarket
FivePointOhh is offline
Old 08-31-2007, 12:48 PM
DoctorD415
DoctorD415's Avatar
Ya i was thinking about doing that anyway, but wouldnt i still need that sensor? Im new to this, how would the aftermarket gauge work and be hooked up. I wanted to go aftermarket on the temperature and on the rpm? How would i do either of these?
Old 08-31-2007, 12:51 PM
FivePointOhh
in limbo
with a mechanical temp gauge there is no sending unit. its a physical measurement of temp. much like a thermometer. when you buy one it comes with a hard line that you run to the lower intake manifold from gauge inside the car. they eliminates you stock one. go check one out at autozone at the sun pro gauges. you can get one of those or your can get a autometer or whatever. but if you want to see what it looks like or what its about go look at the sun pro ones at autozone.
Old 08-31-2007, 12:54 PM
Joel5.0
Joel5.0's Avatar
The problem could be that you're asking for a coolant sensor.....it should be the temperature switch. The big chain auto parts stores have it.
TSU217 under GP Sorensen brand.
F1855 under AC/Delco
TS25621 under Niehoff
TS58 under Standard Motor Products
Joel5.0 is offline
Old 08-31-2007, 01:16 PM
DoctorD415
DoctorD415's Avatar
alright thanks for all the help
Granatelli Sales
01-20-2020 12:34 AM
Nick Oliver
10-17-2018 04:22 AM
svfetter
10-05-2015 11:39 AM
wraith777
09-28-2015 10:49 AM
MusicCity615
09-12-2015 07:05 AM
Quick Reply: temperature coolant sensor...
