help with timing on 94 mustang gt
my mustang is all stock but it was wondering, if I set the timing from 10* to 12* will it improve my cars performance, you know will it respond quicker or does it even matter. What timing should i set it at? And if I do change the timing does the type of gasoline I put in it matter?
RE: help with timing on 94 mustang gt
Typically, advancing the timing will result in a gain in power and throttle response. However, it also typically requires a higher grade of gasoline. You should probably be able to get it up to 16 degrees with 93 octane gasoline. But as always, if you hear pinging then back it off a degree. An increase in 6 degrees will probably gain you around 12 or so HP.
Most people see gains of 1 - 2 hp per degree of timing. The best thing you can do is get a full tank of 91. Then adjust your timing 1 degree at a time. After each degree, go out, hit WOT, and listen for pinging. If you hear pinging, back it off a degree. If you don't hear pinging, add another degree.
If you haven't already, get rid of that stock air silencer as well. That is a free mod and will free up some HP. If you have a little cash, replace it with a nice K&N air filter.
thanks samseed101, Im gonna go fill up the tank with 91 octane and adjust it at 14 degrees and if I hear pinging ill back it off a degree. and yeah i already took off the silencer box and put a K&N filter. Thanks man
ShaneB26154
35
03-04-2021 04:05 AM
KEM Motorworks
08-14-2015 10:13 PM
