30lb injectors with 347
Old 09-09-2007, 10:47 AM
jonalman
jonalman's Avatar
Default 30lb injectors with 347
i was wondering if 30lb injectors are big enough for a modded 347
jonalman is offline
Old 09-09-2007, 10:53 AM
91hatchgt
91hatchgt's Avatar
Default RE: 30lb injectors with 347
What is your definition of modded?
30lb. injectors are probably fine. I have seen people running 24#ers with 347's.
91hatchgt is offline
Old 09-09-2007, 10:58 AM
w8less
w8less's Avatar
i ran 30's with my stroker if built right its fine with them
w8less is offline
jonalman
jonalman's Avatar
i dont have a supercharger or turbo, but i guess the usual , trick flow top end kit, ford e cam. 70 mm throttle body, ect ect
jonalman is offline
Old 09-09-2007, 11:01 AM
grabbem88
grabbem88's Avatar
if i was building a "modded" 347 30lb inj. would barely be enough...
grabbem88 is offline
Old 09-09-2007, 11:15 AM
91hatchgt
91hatchgt's Avatar
ORIGINAL: grabbem88
^^ But as you see he has a mild build. With TW heads and an E-cam, I am sure the 30# inj. will be plenty. Why did you put an e cam in a 347?
Old 09-09-2007, 11:18 AM
w8less
w8less's Avatar
for his build 24s might be enough
w8less is offline
Old 09-09-2007, 11:21 AM
grabbem88
grabbem88's Avatar
since i have a slow net i didn't get to see his post yet.......yeah 24's are plenty
Old 09-09-2007, 05:12 PM
richs347
richs347's Avatar
30's are plenty forthe setup.
richs347 is offline
Old 09-09-2007, 06:35 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
don't you love these dumb *** questions that don't give you any background...I'm glad my crystal ball is working again
2 kwik is offline
GimpyHSHS
19
12-19-2023 01:12 PM
4cylinderplus2
10-09-2020 07:45 PM
Dathan
10-05-2015 05:52 AM
MacSerio
09-27-2015 01:05 PM
EASTIDEE123
09-14-2015 03:52 PM
Quick Reply: 30lb injectors with 347
