Thrust Bearing Cap question.
Old 09-14-2007, 08:56 PM
CCF5000
CCF5000's Avatar
Default Thrust Bearing Cap question.
It states when rebuilding the bottom end to torque all the main caps except the thrust bearing cap to 70ft lbs. The thrust bearing cap is torqued to 12ftlbs then you pry the crank forwards and backwards it says. Then it says retorque all the main caps to 70ft lbs are you supposed to torque the thrust bearing cap to 70ft lbs too?
CCF5000 is offline
Old 09-14-2007, 09:00 PM
dimebag
dimebag's Avatar
Default RE: Thrust Bearing Cap question.
i want to say yes... but plz wait for someone to back me up 1st
dimebag is offline
Old 09-14-2007, 09:03 PM
67mustang302
67mustang302's Avatar
Yes. The reason for the light torque the first time is so that when you pry the crank back the cap can move to align the thrust bearing. Also, it doesn't hurt to get a dial indicator and check to make sure the crank thrust is correct.
67mustang302 is offline
Old 09-14-2007, 09:54 PM
tinman
tinman's Avatar
Yep, after using the dial indicator to check play, torque it to 70 ft/lb.
tinman is offline
Old 09-14-2007, 11:10 PM
my77stang
my77stang's Avatar
i've never seen anyone actually do it that way though. every builder i have watched assemble a motor torques them all down to spec and then gives the counterweights a couple good smacks and then smacks the crank forward and backward to set the thrust.
my77stang is offline
Old 09-15-2007, 08:41 AM
CCF5000
CCF5000's Avatar
hmm you hear so many different things about building motors nowadays I don't know what to believe lol
CCF5000 is offline
Old 09-15-2007, 03:23 PM
silver91gt
silver91gt's Avatar
to properly set the thrust bearing you need to torque all bolts down except the thrust ones, they can just be snug, set the thrust and check it with a dial indicator, then after the thrust is set you can torque the bolts.
silver91gt is offline
6bangr
02-15-2016 07:40 AM
Dathan
10-05-2015 05:52 AM
KingRando
10-02-2015 08:06 AM
Offendant
09-23-2015 07:21 PM
ccdguy
09-19-2015 05:20 PM
Quick Reply: Thrust Bearing Cap question.
