75TB to 70MAF tube
Old 12-30-2007, 07:07 AM
ewgoetz
ewgoetz's Avatar
Default 75TB to 70MAF tube
Where would i look into getting a new tube that has a larger diamiter that will fit a 75mm TB to a 70Maf? I have a BBK kit and noticed that like the stock housing the tub is smaller than the 2 housings.
ewgoetz is offline
Old 12-30-2007, 09:09 AM
tooslow5.0
tooslow5.0's Avatar
Default RE: 75TB to 70MAF tube
why in the world are you running a 75mm t.b. with a 70mm maf? a 75mm t.b is WAY overkill unless your running a full race stroker motor. if thats the case, youll need to get the lightning 90mm maf. rule of thumb is always run a bigger maf than t.b.
i bet ifyou put the stock t.b. back on, you would gain power.
tooslow5.0 is offline
Old 12-30-2007, 09:12 AM
ewgoetz
ewgoetz's Avatar
actualy i have a stock on on atm and was planing on getting a 70 or 75 TB. But still teh tube is a smaller diamiter
ewgoetz is offline
Old 12-30-2007, 09:16 AM
tooslow5.0
tooslow5.0's Avatar
well, i guess to answer your original question, just have a muffler shop bend you a tube in the correct diameter, and attach it with rubber couplings. you could even polish it and have it look nice. or just get some pre-bent stainless tubes at your local autoparts store and cut to lenght yourself.
Old 12-30-2007, 09:23 AM
ewgoetz
ewgoetz's Avatar
Was thinkin of hiting a muffler shop and doing that, Just wanted to se if I had any other options.
ewgoetz is offline
Old 12-30-2007, 04:25 PM
tooslow5.0
tooslow5.0's Avatar
you have a million options if your creative. its just a tube. you can probably hit any pick and pull and find a hundred different rubber tubes from all makes and models that can be modified to work.
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
PB Pod
Forum Issues and Feedback
09-17-2015 08:32 PM
09-17-2015 07:57 PM
BrantleyS550
09-14-2015 04:18 PM
Quick Reply: 75TB to 70MAF tube
