problem with clutch cable after aod to t5 conversion help!!
Old 01-08-2008, 09:58 PM
blk89lx
blk89lx's Avatar
Default problem with clutch cable after aod to t5 conversion help!!
ok so im finishing up my aod to t5 swap and i just put on my clutch cable but it seems like there is nooooo slack what so ever i hooked up the end of the cable to the clutch quadrent and then i had to pull the other end with pliers to get it into the clutch fork. my pedal is soo high and my firwall adjuster is set all the way down. i dont understand whats wrong.
blk89lx is offline
Old 01-08-2008, 10:03 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: problem with clutch cable after aod to t5 conversion help!!
did you do an adjustable quadrant or do you still have the stock set up?? if it's stock pull up on the pedal this releases the self adjusting mechanism and allows quadrant to adjust properly
mjr46 is offline
Old 01-08-2008, 11:00 PM
blk89lx
blk89lx's Avatar
no its adjustable steeda one
blk89lx is offline
Old 01-08-2008, 11:25 PM
blk89lx
blk89lx's Avatar
bump
blk89lx is offline
Fast-Hands
08-19-2015 06:54 AM
stanglx2002
11-16-2006 03:18 AM
stanglx2002
06-05-2005 01:05 PM
stanglx2002
05-05-2005 12:47 PM
Gene68ragtop
02-17-2005 03:56 PM
Quick Reply: problem with clutch cable after aod to t5 conversion help!!
