AOD Tranny Fluid
Old 01-10-2008, 12:25 PM
Speedy911
Speedy911's Avatar
Default AOD Tranny Fluid
I've looked through the search and all but did not find an answer or relevant question.
What Transmission fluid do you guys recommend for a AOD transmission?
It has a shift kit and a 2400 stall converter.
Thanks
Speedy911 is offline
Old 01-10-2008, 03:44 PM
89GTRagtop
89GTRagtop's Avatar
Default RE: AOD Tranny Fluid
Dexron II ATF is the mfg recommended type. I use it and have had no problems.
89GTRagtop is offline
Old 01-10-2008, 04:26 PM
nitrous_bob
nitrous_bob's Avatar
if you use a synthetic which you should, use royal purple or amsoil as best choice, or mobil 1 after that
they just say "synthetic atf"
nitrous_bob is offline
Old 01-10-2008, 08:48 PM
URLACHER54
URLACHER54's Avatar
dont know how good the royal purple is but im getting ready to swap my transmission with a beefed up AOD and thats what im going to use
URLACHER54 is offline
Old 01-10-2008, 10:24 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
dextron III/mercon will be fine.....actually since that patten doesn't exist anymore the bottles now say just "ATF" and in a little box it is written...for vehicles that require dextron III / mercon
mjr46 is offline
Old 01-11-2008, 02:09 AM
greenstreak9205
greenstreak9205's Avatar
i filled mine up with amsoil. all bout $100 worth and then blew my trans like <2000 later. but it seemed to work fine before that
greenstreak9205 is offline
Old 01-11-2008, 07:39 AM
90_Mustang_GT
90_Mustang_GT's Avatar
Ive got royal purple rollin through mine, shift are smoooooth.
90_Mustang_GT is offline
Old 01-11-2008, 08:40 AM
my77stang
my77stang's Avatar
i always used dexy mercy tre' in everything, but went with B&M synthetic trick shift this time in my built C4. can't say i've had any problems with it, also can't say its the best out there. i just know it works[8D]
my77stang is offline
Thunderball
15
11-22-2015 11:49 PM
wraith777
09-28-2015 10:49 AM
treesloth
09-28-2015 07:03 AM
2poor4u2
09-26-2015 11:08 AM
09-25-2015 06:42 PM
Quick Reply: AOD Tranny Fluid
