battery in the trunk
Old 01-12-2008, 10:48 AM
white93pony
white93pony's Avatar
Default RE: battery in the trunk
i would go to summit and spend the money on the kit they offer it comes with everything needed and you will need to buy a cutoff switch to pass tech at most tracks the kits usually dont come with a switch you will need to buy a high amp switch also
white93pony is offline
Old 01-12-2008, 11:12 AM
WhiteWindsor
WhiteWindsor's Avatar
I like the novelty of the batt in trunk, it can be a little effective with weight distibution, but the main reason for me was to clean up engine bay.
WhiteWindsor is offline
Old 01-13-2008, 12:45 AM
89 5.0 vert
89 5.0 vert's Avatar
yeah i was gonna do it to clean up engine bay... and help with wieght distribution... every little bit adds up and helps imo
89 5.0 vert is offline
Old 01-13-2008, 07:59 AM
mantis118
mantis118's Avatar
Im also just doing mine to clean up the engine bay. But hey like everyone else said every little bit helps.
mantis118 is offline
Old 01-14-2008, 02:41 PM
89 5.0 vert
where would be a good place to ground in the trunk for the negative cable? and... with my negative cable there is a smaller black wire that goes with it to the terminal and then it is grounded on the engine bay and then i follow it and it starts to go into the wiring harnes... what is that and what do i do about that???
BOB ROME
07-26-2023 01:54 PM
4cylinderplus2
10-09-2020 07:45 PM
logan409
09-26-2015 07:43 PM
movielover40
09-15-2015 10:37 AM
wilsonro
4 Cylinder NA and Turbo
09-11-2015 07:13 AM
Quick Reply: battery in the trunk
