Best way to clean Cylinder Heads?
Old 01-15-2008, 03:51 PM
irish1
irish1's Avatar
Default RE: Best way to clean Cylinder Heads?
I watched my friends at the local machine shop do it many times, if they are an oily mess they go in the tank to get the worst off so you don't get all that oil in the media blaster. After, they go in the media blaster if needed. Blow them out and do what work needs to be done, then they go back in the tank to get any remaining media out, are blown out again,assembled and painted.
irish1 is offline
Old 01-15-2008, 09:37 PM
my77stang
my77stang's Avatar
P Zero, compare the "cheap" carb cleaner to the "better" stuff and you'll see what i mean. gumout leaves oil behind like your spraying WD40 on the damn thing, but the wally world stuff works quiet well and is uber cheap.
also, steel shot > sandblasting
my77stang is offline
EZFEED
05-05-2016 08:54 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
NYstang
09-30-2015 09:56 PM
b8checker
09-30-2015 07:11 AM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: Best way to clean Cylinder Heads?
