Timing question
Old 01-22-2008, 02:29 PM
camaroeater
camaroeater's Avatar
Default Timing question
I recently have been experimenting with advancing my timing. I set it a 16* w/(91oct) and I had no pinging in 1st or 2nd @ 5800 rpms, but in 3rd gear around 5600 got just a little pinging. So, i turned it down to 15*w/(91oct) and have had no pingingat all for 2 weeks.Do you guys think 15* is alright or should I set it a 14* to be on the safe side.
camaroeater is offline
Old 01-22-2008, 02:31 PM
87Stallion
87Stallion's Avatar
Default RE: Timing question
Me personally I would set it back to 14*.
87Stallion is offline
Old 01-22-2008, 02:48 PM
camaroeater
See, i have heard that different timing lights can have different readings and that harmonicbalancers can be different from 5.0 to 5.0. So thats why I thought the best way is the set and test method, advancing till it pings and then back off a degree to get the most potential of a timing advance for YOUR vehicle.
Old 01-22-2008, 02:53 PM
87Stallion
87Stallion's Avatar
You're right about the test and set. Me personally I like to be a little on the safe side. My 87 is set to 12* I just advance 2* over factory specs.
Old 01-22-2008, 02:59 PM
camaroeater
I had mine at 12*(89 oct) for 1 week, then 14*(91 oct) for 1 week. Now i've been at 15* for 2 weeks. Yea, I know what you mean by being safe cause I'd hate to **** something up from the timing being advance 1* to much.You know 15* is working right now, but its 62 degrees in Arizona right now, i'll probally ping when it 110 degrees here in AZ.
Old 01-22-2008, 06:59 PM
ExMan01
ExMan01's Avatar
what is stock timing set at? and does it make a huge difference to adjust the timing?
ExMan01 is offline
Old 01-22-2008, 07:03 PM
bamaroxz
bamaroxz's Avatar
Stock on a 5.0 is 10*, most run at 12* for safety, economy (as much as possible) and advancing it will make it run quicker, but too much and you'll have problems.
bamaroxz is offline
CarrieS
09-01-2015 01:00 PM
GimpyHSHS
08-29-2015 06:30 PM
Calizic
08-28-2015 01:46 PM
stormesixx
08-25-2015 09:11 AM
ding56
08-14-2015 02:40 AM
Quick Reply: Timing question
