tuneup and now running like ****
Old 01-22-2008, 10:23 PM
XPBaller
XPBaller's Avatar
Default tuneup and now running like ****
I changed my plugs (autolite plats, gapped .054), wires (duralasts), cap and rotor (duralasts), and now it's missing and bucking and running like ****and ithas no *****. I looked over the placement of the plugwires and theyre good,What did i do wrong?
XPBaller is offline
Old 01-22-2008, 10:27 PM
dimebag
dimebag's Avatar
Default RE: tuneup and now running like ****
did you move the dist. by accident?
double check your firing order.... you know what cyl is what right... pass side is 1-2-3-4, and drivers side is 5-6-7-8
im not a huge fan of the plat. plugs... i used to run autolite 25s in my e7 heads...
dimebag is offline
Old 01-22-2008, 11:04 PM
silentvoice19
silentvoice19's Avatar
now did you give him the order for the HO because isnt the HO different from the regular 5.0 motor.correct me if im wron lol
silentvoice19 is offline
Old 01-22-2008, 11:10 PM
VigCS
VigCS's Avatar
You probably have some wires mixed up.
VigCS is offline
Old 01-22-2008, 11:18 PM
XPBaller
XPBaller's Avatar
What do you mean did i move the distributer by accident?? Is there a particular way that the cap and rotor need to go on? my buddy put on the cap & rotor while i was gapping the plugs and i checked over and the wires were all put back in the proper order..
im pretty sure i dont have any wires mixed up. I've gone through and unplugged and replugged the wires in as well to make sure i didnt have any that werent popped on..
XPBaller is offline
Old 01-22-2008, 11:30 PM
Asylum839
Asylum839's Avatar
just incase you needed it.
Asylum839 is offline
Old 01-22-2008, 11:52 PM
XPBaller
XPBaller's Avatar
Thanks dude,i acutally had it written down and by now memorized well...
well, i brought my girlfriend and a flashlight out at 1 am and, even though i had already double checked the connections, i decided to triple check them. Unplugged and replugged the wires atthe plug anddizzy,took the cap off and put it back on,took it for a test drive, no more miss =], i guess a wire just wasnt on right... sorry for the false alarm, but thanks for being on point so quick with the responses!
XPBaller is offline
Old 01-22-2008, 11:53 PM
VigCS
VigCS's Avatar
ORIGINAL: XPBaller
He meant did you rotate it by accident? It sounds doubtful becuase I doubt you loosened the hold down srew. There's only one way the distributor cap goes on because it's keyed. Make sure your wires are using the HO firing order and not the regular firing order.
VigCS is offline
10-07-2015 07:02 PM
heslekrants
09-23-2015 04:02 PM
TorinoCobra070
SVT Forums
09-18-2015 10:34 AM
MusicCity615
09-12-2015 07:05 AM
uedlose
09-10-2015 03:30 PM
Quick Reply: tuneup and now running like ****
