Rebuild AODE?
Old 02-06-2008, 08:58 PM
cougarfan088
cougarfan088's Avatar
Default Rebuild AODE?
how much would it cost to get my AODE rebuilt on average? and what would a rebuild consist of?
cougarfan088 is offline
Old 02-06-2008, 09:34 PM
cougarfan088
Default RE: Rebuild AODE?
can anyone help me on this?
Old 02-06-2008, 10:09 PM
c4king
c4king's Avatar
stock rebuild? h/p build? is there anything wrong with it now?
c4king is offline
Old 02-06-2008, 10:11 PM
cougarfan088
um about 400 hp when done...it has 120,000 miles on it and im replacing everything in the engine so fixing the tranny while its out..probably just a stock rebuild then shift kit and valve body..
Old 02-06-2008, 10:15 PM
c4king
c4king's Avatar
if you do it your self i would say around 200.00 bucks includes rebuild kit, clutches, and shift kit, but if your pushing around 400 h/p i would use red alto clutches and kolen steels, with a trans-go shift kit...the alto clucthes are prety salty but it wont slip
c4king is offline
Old 02-07-2008, 08:42 AM
cougarfan088
how hard is it to rebuild it yourself? and what is kolen steels?
Old 02-07-2008, 09:01 AM
nitrous_bob
nitrous_bob's Avatar
ORIGINAL: cougarfan088
um about 400 hp when done...just a stock rebuild then shift kit and valve body..
how many times a month do you plan on rebuilding it ?
stock rebuild doesn't hold up to 200hp for more than a year
you really need better clutch packs and mod it so it oils better, manual valvebody, oil cooler lots of stuff. don't go less than 3000 on your converter or you'll be dissapointed. 400 hp on your car should flash about 3000, maybe just under
nitrous_bob is offline
Old 02-07-2008, 11:34 AM
cougarfan088
i already have a manual valvebody and new cooler nad im gonna get a new converter...is there like a trans upgrade package i should get that will have like all the upgrades and such?
Old 02-07-2008, 05:56 PM
FLcracker9
FLcracker9's Avatar
I've stated on here before, the AOD is not for the beginner. You will need a couple of special tools to complete the work. After saying this, I will also say it canbe done by the first timer, if you don't rush, and double/triple check your measurements. I highly suggest you purchase a DVDthat will guide you step by step. The Badshoe DVDis one of the better ones, I own a copymyself.
http://www.badshoeproductions.com/products.html#aod
FLcracker9 is offline
Old 02-07-2008, 06:09 PM
URLACHER54
URLACHER54's Avatar
google, Performance Automatic Racing Transmissions, they have what is called the street smart package for around $2000 for the AOD or the AODE. it has heavy duty clutches, a shift kit and valve body that allows you to shift manually for racing. and the AOD is rated up to 450 HP, the AODE is rated up to 550 HP, and the best part is it comes with a life time warrenty. you can buy them through www.jegs.com and www.cjponeyparts.com. as soon as i get my taxes back im getting my AOD.
URLACHER54 is offline
Dathan
10-05-2015 05:52 AM
Drastang
09-30-2015 03:48 AM
marc954
09-29-2015 03:05 PM
marc954
09-25-2015 06:48 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Quick Reply: Rebuild AODE?
