E303 CAM.... please help
RE: E303 CAM.... please help
ORIGINAL: warggod
you see i already bought the cam and installed it summit told me i could run this on a stock motor shouldnt be a problem they said as long as i dont go to big i should be fine
ORIGINAL: warggod
now i gess im stuck with out a car for now till i get some rollor rockers and shimms i was told from auto parts store they said thats what ford was recommending
if your stock motor is 1.6 and not 1.7 you are a ok. Shims for spring pressure unless you go above .500 lift you shouldn't need to change anything except the cam my 95 cobra came from the factory with a B which is .480 lift with 1.7 rockers which naturally has less room than 1.6 anyday of the week.
Let me see....... the OEM valve springs specs for the E7 heads are:
Intake:
Valve Closed Installed Height: 1.8"@82#
Valve Open Installed Height: 1.33"@230#
Coil Bind Height: 1.250"
Lift to Coil Bind: .550"
Exhaust:
Valve Closed Installed Height: 1.6"@85#
Valve Open Installed Height: 1.15"@226#
Coil Bind Height: 1.090"
Lift to Coil Bind: .510"
E-303 with 1.72 rockers = .535" lift..... so the exhaust springs would become solid (bind) all the time, add some revs, and the intake springs will also bind. The '95 Cobra came with a HR cam that had .480" lift with 1.7 rockers, but it was not a B-303...... the B-303 with 1.7 rockers = .510" lift and is not emissions legal. The GT40 heads used in the Cobra engines had a different set of springs than the ones described above though...... suggestion..... at least match the valve train for the new cam requirements, repairs could be expensive...... BTSTDT with a customer that did it wrong with an E-303 cam. My
Intake:
Exhaust:
