CAM Shim Question
RE: CAM Shim Question
The stock push rods may be fine, but you would still need to upgrade to Roller rockers and use the shim kit to get the preload set correctly. The reason for upgrading the springs is so that you don't see valve float. The stock springs are really weak, and can barely support the stock cam, when you add a bigger can, you need to upgrade to a better spring.
Well yeah, you really only have the one option. You can't just buy new valve springs and the shim kit, because you cannot shim the stock rockers. You buy the shim kit in order to properly set the preload on adjustable roller rockers.
so i cant use shims on my stock rockers stupid summit tech
if thats the case then i should get the value springs the conversion kit for changing my stock heads
to stud mounts and buy some roller rockers
RIGHT...............
ORIGINAL: warggod
ORIGINAL: warggod
if thats the case then i should get the valve springs the conversion kit for changing my stock heads
Luke9222
10-22-2015 11:55 PM
Daddys Girls GTs
09-14-2015 08:46 PM
