tps helpp
Old 02-12-2008, 04:39 PM
steve r
steve r's Avatar
Default tps helpp
On my cousins mustang.. 1990 gt 5spd.. The tps sensor was causing the car to idle at 3k rpms sometimes..so we unplugged it and its perfect...now 8 months later we buy a new sensor and install it and it does the same thing..so we unplug it again and now its fine again, but im trying to figure out what else it could be. thanks in advance!!
steve r is offline
Old 02-12-2008, 05:36 PM
Joel5.0
Joel5.0's Avatar
Default RE: tps helpp
Disconnect battery for 15 minutes, in the meantime, reconnect the TPS, then, reconnect battery, start engine and test drive for 5-15 minutes (even with the problem)...... shut it down, run the DIY KOEO/KOER/Cylinder Balance Self-Test and LUK what shows up in terms of failure codes. Don't gue$$..... verify what the EEC system is working with.
Joel5.0 is offline
Old 02-12-2008, 05:39 PM
Curlytop
Curlytop's Avatar
also try cleaning or replacing i.a.c. try cleaning it first
Curlytop is offline
Old 02-12-2008, 07:51 PM
cobrakiller306
cobrakiller306's Avatar
you need to adjust the screws on the tps and check with a volt meter, position it to i believe......closest to 1 volt. i believe, doo some research and check, i can't exactly remember, but if thats way off, that will effect idle.
cobrakiller306 is offline
Old 02-12-2008, 08:04 PM
REDS 5.0
REDS 5.0's Avatar
TPS voltage should be around .98
REDS 5.0 is offline
Old 02-12-2008, 08:12 PM
Joel5.0
Joel5.0's Avatar
ORIGINAL: cobrakiller306
ORIGINAL: REDS 5.0
That is a mythological solution that will not solve anything.... as long as the TPS closed throttle value is within .5 - 1.19 vdc (.7 - 1.0 vdc optimum)... the system will work fine. The system has a computer with a logic programmed ... use it.
Joel5.0 is offline
Old 02-12-2008, 09:07 PM
steve r
steve r's Avatar
on the tps sensor in the middle of the philip head screws theres a hole..On my car there is a cap over it. on his car there is nothing, could that be something
steve r is offline
Old 02-12-2008, 10:05 PM
Joel5.0
Joel5.0's Avatar
ORIGINAL: steve r
Nope.... BTW.... TPS holding screws are not phillips head screws.... they are pozidrive #2 (very similar to phillips)..... reason why they are a little hard to loosen, or will strip when you use a phillips screwdriver or bit.
Joel5.0 is offline
Old 02-13-2008, 12:01 AM
dudeboy
dudeboy's Avatar
There is a thread in the '!!!Tech Articles!!!' list that has been contributing to the myth of setting the tps to read .98v to 1.00v....
Check this link for a better description...
https://mustangforums.com/m_4613249/tm.htm
when a sensor is unplugged, the ecu goes into alternate strategies.
Unplugging a sensor is not a reliable way to diagnose a problem.
As Joel has suggested, start by checking for diagnostic codes...
good luck,
jason
dudeboy is offline
ShaneB26154
35
03-04-2021 04:05 AM
mirandaandjimmy
11-16-2015 08:51 AM
JonnyBlazeGT
11-03-2015 01:10 AM
69MustangCoupe393cid
10-03-2015 10:33 AM
bmorrisj
05-27-2004 06:18 PM
Quick Reply: tps helpp
