Electric fan HELP!!!
Old 02-13-2008, 07:13 PM
87greyghost
87greyghost's Avatar
Default Electric fan HELP!!!
I have a 87 mustang gt. It has an electric fan in it that came out of something else it was in it when i got it. It kept blowing fuses but did not have a short. I direct wired it to the battery through a relay with a fuseable link on it and have it hooked up so when i turn the key on the fan comes on. For some reason every once in a while it will melt the fuse in the fuseable link. It starts melting at first then blows it. Anybody know what the problem might be. I got it on a 30 amp relay with a 30 amp fuse
87greyghost is offline
Old 02-13-2008, 07:19 PM
302f150
302f150's Avatar
Default RE: Electric fan HELP!!!
its broke. electric motors are basically a series of dead shorts. if if stays shorted in one spot too long(bearing bad, build up, something) then its gonna draw a lot of current. unless u just have really small wires running to bigger wires....but you wouldnt do that right?
302f150 is offline
Old 02-13-2008, 07:22 PM
302f150
302f150's Avatar
buy a universal cage fan or something with at least 1500 cfm's, u can find them for like 50 bucks
302f150 is offline
Old 02-13-2008, 07:23 PM
87greyghost
Na the wires are same size all the way basically. The wires that go from the inside of the car to the relay that turns the relay on arent small but there not big but that really dont matter they just activate the relay. the wires coming from the fan are the original wires except for about 6 inches which arent that much smaller.
Old 02-13-2008, 07:27 PM
302f150
302f150's Avatar
as long as the supply wires are bigger than the original fan wires, and not vice versa. there is a 14.5 inch straight blade fan rated at 2000 cfms for sale on ebay for like 30 bucks. but it will be loud as hell. try to get one with curved blades
302f150 is offline
Old 02-13-2008, 09:10 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
You might want to also check and see how much current is being drawn while the fan is running. It might be right at the limit of the fuse and heating it up to the point of breakage.
projectresto83 is offline
BOB ROME
07-26-2023 01:54 PM
PaulH2
20
01-31-2016 09:48 AM
Seanam
10-04-2015 10:15 AM
mrappe
09-26-2015 10:16 AM
09-25-2015 09:06 AM
Quick Reply: Electric fan HELP!!!
