Line lock/Roll Control
Old 03-30-2008, 04:10 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: Line lock/Roll Control
Every track I have been to so far is level at the line and the car doesn't roll. I'm not saying you can't use, I just don't. There's ne need for me to.
You can get a trans brake for a better affect at the line. W/ line lock, only the front wheels are locked and if you have enough power and a sticky tire, you could push past the staging light and red light at the line
In drag racing, a transbrake is a setup installed in automatic transmissions which places the transmission in first and reverse gears at the same time, effectively "braking" the transmission. With the transmission locked in this manner, the engine can be accelerated to a certain RPM in preparation for launch and the racer doesn't need to worry about the car creeping forward. A split second before the green light illuminates on the Tree the transbrake is released (either automatically by a delay box or manually by the driver) and the car launches forward, its engine already at the beginning of its powerband and the transmission is already in gear.
PRO50SC is offline
Old 03-30-2008, 04:31 PM
302army187
302army187's Avatar
ok, thats what i was thinking of was a TRANS brake, i thought they where both the same.
thanks!
302army187 is offline
Old 04-29-2008, 01:46 PM
kremer306
kremer306's Avatar
I installed a hurst line lock the same time I converted to 5 lug brakes on my 91 mustang and I cant get the brakes to firm up Ive already chang the master cylinder and that didnt help how can I fix this any ideas
kremer306 is offline
Old 04-29-2008, 01:51 PM
bighungrymatt
bighungrymatt's Avatar
did you bleed your brakes? I also read where if your line lock is mounted above the master cylinder you cant get all the air out of your brake lines
bighungrymatt is offline
Old 04-29-2008, 01:57 PM
kremer306
kremer306's Avatar
yes line lock is mounted lower than the proporting valve
Old 04-29-2008, 03:06 PM
bighungrymatt
hmm, maybe try bleeding brakes again? Start from furthest away from Master Cylinder
Old 04-29-2008, 04:01 PM
hi_tek_rednek
hi_tek_rednek's Avatar
my 89 5.0 has 2 front lines and 1 rear line coming out of the master cylinder. 1 front goes to the prop valve and 1 doesn't. it goes straight to the driver side caliper. how should i connect a line lock?
will...
hi_tek_rednek is offline
Old 04-29-2008, 07:19 PM
kremer306
kremer306's Avatar
the way hurst shows to hook up line locks is to plug off bottom port on master cylinder and thats how I did it and I have bled the brakes 4 time so far. could it be because I converted to rear disc and sn95 front disc brakes.
do I need a bigger master cylinder
Old 04-29-2008, 08:28 PM
fordboyyfm
fordboyyfm's Avatar
i put a hurst kit on a friends car, he got it off of ebay and the install kits was just a few lines and fittings in a bag, im not sure if it was a hurst install kit or just some junk thrown together but it was usles, i just made the lines and all to do it, the fittings that came with it kept leaking so i tore it all out and redid it.
fordboyyfm is offline
Old 04-29-2008, 08:36 PM
NYMustang50
NYMustang50's Avatar
ORIGINAL: bighungrymatt
yea i would and start at pass rear and driver rear and pass front and driver rear after. also make sure your partner is holding down the brake and you have brake fluid in the master.
NYMustang50 is offline
jwog666
12-27-2021 08:09 PM
mrtrodonet
09-19-2020 03:12 PM
TCStangerv6
10-11-2015 05:57 PM
ChampInSD
10-02-2015 04:55 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
Quick Reply: Line lock/Roll Control
