FUEL PUMP STAYS ON AT ALL TIMES , NEED HELP
when i turn the key the fuel pump should come on for a few seconds then shut off . but i hear the pump on all the time and it is flooding the engine with out starting it . something is going on . i changed the fuel pump module relay box that is located by the over flow tank and the car computer and it is still staying on when i turn the key on with the engine off .
WHAT AM I DOING WRONG AND WHAT SHOULD I LOOK FOR . HELP !!!!!!!!!!!!!!!!!1
RE: FUEL PUMP STAYS ON AT ALL TIMES , NEED HELP
First off. You must chill. Second off. I don't think it's flooding it. The injectors shouldn't be pumping the fuel. The fuel pump will just be pumping it to the rails, and then to the return line. So you might have other problems (THis is fox body.. I assume SN95's aren't that different). I Guess I'd start checking wires.. http://www.veryuseful.com/mustang/te...ng_Diagram.gif
Maybe the relay isn't releasing (Would find that odd)...
ORIGINAL: ponyboy302
isnt the fuel pump supposed to stay on ?
ORIGINAL: ponyboy88
+1 on the relay its under the drivers seat in foxes
Design1795
01-24-2017 10:38 PM
Design1795
08-24-2015 04:41 PM
jpplaw
08-22-2015 09:29 PM
