Quick brakes question
RE: Quick brakes question
ORIGINAL: Jasperstang308
is there any difference between a sn95 v6 and sn95 v8 front brakes?
94-98 are identical
New Edge 99-04 are identical
That being said...there is no difference.
Upgrade path would be a Baer System or a Cobra system from similar years.
This may help you a little. Got it from http://www.sn95brakes.com
'94-95 V6 & GT: 10.8x1.0" front rotors, 66mm single piston calipers. Rear single piston 38mm Varga caliper, 10" solid rotor
'94-98 Cobra, '95 Cobra R: 13.0x1.1" KVH rotors, 38x38mm dual piston PBR calipers. Rear single piston 38mm Varga Caliper, 11.65" vented rotor
'99+ V6 & GT: 10.8x1.0" front rotors, 44.5x44.5mm dual piston PBR calipers. Rear single piston Varga caliper, 10" solid rotor
'99+ Cobra: 13.0x1.1" Brembo rotors, spec'd 40x40 mm dual piston PBR calipers. Rear single piston 38mm Varga Caliper, 11.65" vented rotor
'00 Bullitt Mustang: Same brakes as 94-98 Cobras (unique red PBR calipers with running horse up front, same varga caliper in rear painted red.) Rear single piston 38mm Varga Caliper, 11.65" vented rotor
'00 Cobra R: 13.0x1.1" Brembo rotors, Brembo 4 piston calipers. 36x40mm pistons. Rear disc the same as the stock '99+ Cobras
